Im working on a Speedway Shrike. At first it wouldn't start without starting fluid and then it wouldn't keep running. I opened up the Carb and it was very corroded and the float was bad,, I soaked i and the Needle seat melted,, So I bought brand new carb from OldMiniBikes after bolting on the carb and filling the bowl with gas It started with about 5 pulls and settled to a smooth idle high but smooth today I hooked up the linkage nd set up the clutch so I could take it for a test drive and its hard to start like 15 20 pull then a pop 10 more pulls and it started Im wondering if I have the wrong plug my son put new plug in and he said it was what cme out but Im not sure if what came out was the right plug the engine is a H30 -35264H serial 20483 the plug in it is a champion 5843 any one know what plug should be in it?
