Techumeh hs50 straight pipe
Hi guys i bought a straight pipe from OldMiniBikes for my techumseh hs50. I was wondering if it will damage the engine with just the pipe or should i put a silencer on it.. Thanks
Sent from my iPad using Tapatalk
As long as you have six inches or so to keep the exhaust valve from cooling too fast on shut down, you are okay. (Less length required if you have a silencer/screen that will retain heat a bit)
If the pipe is longer than a foot, (or so) you should support it, so you don't pull the mounting bolts out.
Tecumseh's really like to have open exhausts, the more the better.
