I am trying to get a H35 running on a Bonanza I have. I can turn it over and fell the spark if I hold the plug wire end in my hand. But its not enough to spark the plug or arch when i ground it to the block. I took off the flywheel and cleaned the contact points on the flywheel and the magnets. I also tried adjusting the magnets to be closer, but still the same issue. Reading some of the othr posts, would a new coil setup with the magnets be the way to go?
The motor has been sitting for 10-15 years, it has great compression still.
