Hey Guys
I thought i would explain how to make the linkage. It only takes a few things to make it. I use a 90 degree 2"x2" metal bracket. 2 small self tapping screws, a conduit retainer w/locknut, small strong spring, one of the little bars from the governer, and a wire swivel.
First i cut off 1/2" off one side if the bracket. On the cut side twords the end i drill out a hole to fit the conduit retainer. Then drill out 2 holes on the other side of the bracket just bigger then the self tappers. I hold the bracket on the flywheel cover so it would be in line to the throttle arm on the carb, and mark the holes. Then predrill the 2 holes to start the self tappers. Screw the bracket to the cover.
Now some Tecumseh carbs have the small hole right where we need it. But not every one does. So in this pic i show where i would drill the hole for this carb.(the carb would have to be off the engine for this) I like to drill it out 7/64". It has to be set back at the end by the iddle screw. So when it pulls it will pull the throttle open. Make sure you drill it in the right spot or the throttle wont open and close well.
In the next pic you can see how i ran a return spring from the carb to the conduit retainer bracket. Some carbs are different and you have to place the spring at different angles. As long as its pulling back on the throttle arm to hold the trottle closed (if you have this setup right when you pull the throttle it will snap back perfect each time. It is verry important to have the return spring well attached on both ends. You can even use 2 springs to be safe.
You might have to cut the throttle cable housing to get the cable the right length. Put the throttle cable through the retainer. Take one end of the governer bar that still is bent and put it in the hole you drilled. Hold it in line with the throttle cable (i like to split the difference between the conduit retainer and the throttle arm of the carb) Bend it around to make a loop with a small hole in the middle. Cut off the extra bar. Run the throttle cable through the small hole in the bar. Make sure the throttle cable housing is sitting good in the trottle. Then put the wire swivel on the cable, hold the wire and bar straight, and tighten it.
Now test it to make sure everything is working properly. And thats it!
