I'm rebuilding the carb for an HS40 and noticed in the closed position the throttle shutter is not square to the carb body. Is it normal for it to be at a slight angle?
Makes sense. Wasn't sure when I saw two small hole in the carb body where the plate should be relative to the two holes. It's probably obvious that I'm a complete nimrod
Did you remove the throttle plate? Each model has marks to ID them and which way they go. (like a stamped line) a series 1,6,8,9,10 is like this (i) A series 3 and 4 is like this ( -) screws should be replaced or lock tited if removed.
I got a rebuild kit for my carb and have figured out where most the gadgets fit except the O ring and rubber washer. Do they both go on the idle adjustment screw?
