There are several models of Tillotson carburetor to choose from and there is a bit of confusion as to what the model numbers mean and what size is best for each application. I asked my friend and mentor EC Birt (THE Tillotson man) to help out the mini bikers and we came up with this little tutorial. The current offerings available from Tillotson that you might be interested in are as follows:
HL-304WX - .875 venturi, 1.00 shutter. This carburetor is spec'd to have a lean drill pattern and to be prepared by the importer or builder to the customer's specifications. One thing for mini bikers to keep in mind is that this carb is really meant to be an alcohol carburetor once it's drilled. It has double volume stacks and a large inlet needle and seat not needed or necessarily desirable for most gasoline clones. Why isn't it good to have more volume? Well, you want the carburetor to be close to your needs in its basic form and only make fine adjustments with the needles. Closer it is to having the correct fuel curve, the easier to tune.
HL348F - .875 venturi, 1.00 shutter. This is a purpose built alcohol carburetor made for kart racing and is ready to go for OHV engines burning methanol.
HL-334WX - .790 venturi, 1.00 shutter. This carburetor isn't talked about much, but might be the best choice for most of the mini bike clones that are being built right now. The carburetor is setup to be a gas carburetor and is very close if not perfect right out of the box for gasoline OHV engines.
945 Special - This is a 304wx where the venturi has been bored to .945 and the throttle bore to 1.06". Drill pattern is optimized for the open class engines. This is the carburetor for the highly built cones with bigger valves and high lift cams.
All of these carburetors are upgradeable with special machine tricks and other blueprinting tasks to make your carburetor even better than out of the box. If you have any questions, you can PM me and I will get you an answer.
