Hi, I have a tillotson 212 E-start on an mega moto 212 frame. I wanna add an extension to make draining oil cleaner + easier, EDIT, I just checked before mounting the engine it seems the front OEM plug will hang over the frame for an easy clean draining but while I'm making the thread I figure might as well see if anyone knows the thread details for that bolt. Because with one of my big mowers it was a certain type that was close but not the same as there's a few different types and this is not something you want to cross thread! I like the rubber hose type and there was something also about the yellow spring-loaded tool-free draining hose one that got a lot of bad reviews about leaking so I want to avoid that and OK with a bolt-end. Or just the straight metal ~" pipe.
According to this, it's the same thread as Predator which is probably more commonly know thread
https://www.eccarburetors.com/Tillotson-196-212-225-Drain-Plug-Bolt_p_849.html
