I put my motor together. Gx200 with gx160 head, flat top, .265 dyno cam. And when I go to start it, it had so much compression that it broke the pull start. So I check the compression release and it really isn't working. Like the release works on the cam but it won't push down the exhaust valve. I switched the push rods to some predator ones and it didn't help. I also noticed the intake rocker arm isn't touching the intake valve all the way, just resting on the valve retainer. I think it's the lifters but I could be wrong. I'm using everything from the gx160 head along with gx160 lifters and push rods.
Any help will be greatly appreciated.
