The Comet 20 is the most economical replacement. It is available for 1" shaft. To use with a Tote Gote, you would need to find a 1/8" spacer to fit between the two clutch halves. Comet makes a 1/8" spacer for the 3/4" shaft clutch but I haven't seen one for the 1". The Comet 20 usually fits a 3/4" wide belt. The spacer makes the clutch fit the 7/8" wide belts used on a Tote gote. A spacer washer could be found on sites like 'Granger' or 'McMaster Carr'. Look under 'thrust washer'.
