WOW jeep2033,what happen there:doah:
color you are using looks to be a metallic green/turquoise?
maybe one of the best things you could do is clear your floor before repainting the jeep and then wet the whole thing down with water. this will keep the dust down. also may want to look into a colder reducer. they make a cold,med,warm(low temp 60 up 90+)
if you are using a metallic paint you might want to look into a basecoat/clearcoat. spray 3 or 4 coats of base and then fog your last 2-3 coats of color,so the metallic lays down even. then clear it 4-5 coats and then go back and wet sand the whole thing out. paint can look like hell when finish clearing it still for a hobbyist, but when you wet sand it out and buff it you will never no:thumbsup:.smooth as glass
