As far as spacers from right to left in increasing order to think about it easier. Start with your adjusters on both sides. Slide axle in from brake side, goes through one washer, then the adjuster on the swing arm, small spacer, brake bracket, medium spacer, in through the bearing, through the wheel, through the other side out the bearing, through the longest spacer and exit through the sprocket side adjuster.
