My go kart's small gear is stripped and it can't be ridden until the gear is replaced. It's a Manco Phoenix Baja 200 (It's just like a Manco Dingo, they might have even just changed the name). Anyways, there's a 30 series torque converter, and attached to its shaft (not the engine's shaft, but the other part of the torque converter, its shaft) there's a small gear that connects the chain to the big gear (which is attached to the drive axle).
I'm not sure if this little gear is part of the 30 series Comet torque converter or if it's considered a Comet part, but it's attached to (by a key) the torque converters shaft (not the engines shaft, but the shaft for the other torque converter component).
Sorry my explanations
ut: absolutely suck. I'll try to come up with a picture of some sort. The problem is, I would just take a picture, but the go kart is out of state where there's no internet. The next time I see the kart I want to be able to just change the gear and go.
Thanks in advance.
Thanks in advance.
