replacement
  1. R
    Brake Cable Replacement( General Appliance MW Bike)
    Hello All, Can anyone tell when I can get a good quality replacement cable for the brakes on my 1971 Montomery Wards bike l want to either reuse the existing cable or get a good quality replacement. No sure if I will be able to get the molded end section on the new cable. Thanks for the time...
  2. cpu77
    Murray Mini Bike Replacement Carb
    I have a Murray mini bike which I would like to replace the carb on. It has the factory 3.5 Tecumseh Motor. Can anyone give me the part number of the carburetor I cannot find any info on the actual motor. I want to get it running before I sell it.
  3. M
    Brake drum shoe pad replacement
    I'm working on what appears to be a Chinese mini chopper, recently the back brake pads fell off of the shoe (they weren't adhered to the shoe) and cracked. Any ideas where I can get new pads for them? Looked just to buy the whole shoe, but none of them online match up with what I need. Thanks!
  4. Hawaii5077
    Can anyone recommend replacement Azusa mini bike brakes?
  5. C
    Coil Wire Replacement
    The hard plastic spark plug cap got broke on my engine. Is the coil wire replaceable on these or is it molded into the coil? Pictures online make it look like it comes off the coil.
  6. Sprocket86
    MTD/Columbia V Plex Tav replacement.
    Hi there. Has anyone replaced their MTD/Columbia original V Plex Tav driver and driven pulleys with Comet 30 series components? My original V Plex driver is shot and the driven one has the jackshaft seized in place :( How did these original units perform compared to a Comet piece? Thanks
  7. K
    benelli mini bike engine replacement
    a buddy got a benelli mini bike frame without a motor. has anyone adapted a newer pit bike engine into 1. please help
  8. Cuda54
    Engine replacement?
    I would like to put a 340 2cycle into my TRI-ROD anyone ever use a 340 Yamaha snowmobile engine in anything? I know TRI-SPORTS used snowmobile engines like this. So I thought about putting this into my TRI-ROD I would change the primary and secondary too. I think it would make it more fun to...
  9. BWL
    New Mud Motor | Champion 196cc Replacement Engine
    https://www.youtube.com/watch?v=GJ7a0sVEQj0
  10. FOMOGO
    Engine replacement in a Club Car golfcart
    I have a ClubCar Carryall that I use to work around my 8 acres. It has the reverse rotation Kawasaki 350 engine. What a piece of junk. It runs good, it functions but it is just a piece of junk. I have a horizontal shaft V-twin Kohler off of a Yazoo mower. I have been pondering using this in...
  11. R
    Bulb Replacement on Baja 196cc
    Just ordered new bulbs for my 2010 bikes. Does anyone know the best way to get the headlight apart?
  12. R
    Replacement tube size?
    The tire and tube I have are Ardan, 12.5/4.50-6. What size tube do I need?
  13. wildbill59
    HS40 replacement carb? Need #s please!
    Well, looks like the carb on my old Sears puddle jumper is finally plain worn out. I've had pretty good luck with aftermarket carburetors, but I'm not finding any replacement #s for mine. The engine is an HS40 55515G, carb part # is 631667. I've got plenty of mower/snowblower carbs laying...
  14. C
    Jackshaft replacement Fox trail bug?
    I see several on Ebay and wonder if any would work with my trail bug project. My dad tossed mine as a kid when the chain started jumping and we went with one longer chain instead of two. The attached pic is not my bike but an example of what it looks like. Any suggestions?
  15. S
    DR 70 front wheel replacement
    I have been looking all over the internet for replacement front wheel for a DR70. This is a discontinued item. Does anyone have any info or ideas?
  16. james ackerman
    Need replacement fork boots.
    I am looking for these exact fork boots, they are off a ccs ram charger with internal shock rods. Does anyone have any like these, or know of a bike that uses these same boots that I could keep my eye out for.
  17. C
    Rupp TC1 replacement
    Any suggestions on a replacement for the original TC1 off a Rupp Roadster 2?
  18. W
    Baja Racer=Throttle to Governor Spring Replacement
    Hi All - I was referred to this forum by Victoria at OldMiniBikes Warehouse customer service. My problem is I picked up a Baja Racer that is missing a spring that attaches to the throttle lever and the governor. I am having a hell of a time trying to find this spring or getting any tech support from...
  19. OND
    Powell Driven Bearing Replacement
    Just as the title says, I'm replacing the bearings on my Powell driven. Also I'll add some 1/8'' spacers between the pulley halves so I can use a 3/4'' top width 20 series TAV belt. This is the driven torn apart. This is the main shaft with the old bearings still on it...bearings are a...
  20. J
    HELP - Replacement for DB30S Rear wheel set up
    Ok, I'm hoping someone has had this challenge. I can't find a rear wheel for my kids DB30S -- serial number starts with the LUAH... What / How did anyone come up with a work around? Thank you in advance for your knowledge and advice. Jeff
