My fiancé and I have matching Coleman CT 200 U minibikes. Installed a TAV on mine. Installed one on hers shortly after. Ever since the beginning I have been noticing hers has less RPM at top and as mine does. With TAV installed and only the throttle screw cut I can get 35 to 38 mph. Hers tops out at 30 and feels like the governor is prematurely engaging. Out-of-the-box minded 21 hers did 19. Had the similar sound of just a lower RPM at top end. Any suggestions on what I can do to increase her RPM? I am not removing the governor and Will not. I can tell something is slightly difference between the two just by sound. Visually the throttle linkage and governor spring look identical. I did tighten up her cable to get a better response, it helped a little but not significantly. Please help.
