Having a hard time here:mad2:. Got an engine on the black unknown frame (scratch built possibly), pulled the second #35 split sprocket off the existing #41 sprocket, put in the correct wheel spacers (the existing were too large of an ID and were pressing on the bearing shield instead of the inner race) and threw a chain on it. Got the engine running, hopped on her and took er for a little test
. Started picking up speed and heard some funny noises, looked down at the back sprocket and noticed a lot of wobble...the sprocket and the wheel are not concentric, it's pretty bad, then the chain popped and locked. The sprocket is terribly thin anyway and I need the real deal put on here. So I'm looking all over for a sprocket that will match the bolt hole pattern of the rear wheel which is 6 bolt holes, clearance for 5/16 bolts, on a 4-3/4" bolt circle. I cannot find any kind of sprocket with this pattern...what kind of wheel do you think this is (two piece steel, 5")? I'm about ready to just get another back wheel, the correct spacer type(s) and the correct sprocket, but I'd like to not have to buy another wheel.
