Both of these engines have the lighting/charging coil.
The black one is newer and runs with great compression but the carburetor needs servicing. Electric starter works and the plastic tank is solid and does not leak. 1" wide and 3" long shaft. Still set up as a snowblower engine so it does not have a air filter assembly. Asking $50 for this one.
The white one is older and also runs but the gas tank is no good. Does not have an air filter assembly as it was a snowblower engine. Shaft is 1" in diameter and is about 3" long. Asking $30 for this engine.
These can be shipped, buyer pays actual shipping (From 53227).
Will drop the price to $70 if you buy both.
