8hp
  1. MTchevy1
    WTB Briggs 8hp flat head parts
    Looking for a fuel tank, air cleaner assembly, and muffler for a long block I picked up. Let me know what you've got- thanks!
  2. jaimenv
    Is this a B&S 8hp animal ?
    Got the engine from the scrap yard with a busted rod, apparently no damage to the block other than the topside oil filler/dip stick boss. It came with a splined short crank shaft attached to a gear reducer of sorts that was trashed in the inside. I am looking at replacing the crank with a...
  3. J
    New guy with a Dunecycle, Tecumseh 8hp
    Hey there. I've got a Dunecycle with an 8hp Tecumseh engine, from what I've researched so far. It's been sitting for who know how long but after some simple checks and and external fuel supply it started up pretty well. It appears to have a Mikuni vm22, governor removed, and maybe an...
  4. lostinbaja
    Tecumseh 8hp ID help.
    I'm going to look at a 8hp Tec for my Super Bronc tonight. Can anyone tell me how I can tell if it is a ball bearing engine or a bushed engine without tearing it apart? Thanks for the help. Jerry...
  5. Studeman68
    8HP Tec in Penn.
    Not a bad deal if you can pick up.. Set up for electric start and has an alternator... John Deere TRS26 8 HP Tecumseh Engine HMSK80 155418T Snow Blower Thrower | eBay
  6. 125ccCrazy
    Does anyone know what peformance parts fit a 8hp predator?
    Our son bought an 8hp Predator 301cc for a gokart project and he wanted to know what performance parts are available? I'm not sure if gx270 or gx340 parts interchange or if this engine is all by itself... any info would be great.
  7. Possom point
    8hp Briggs from Homelite LR4400
    [/URL][/IMG][/URL][/IMG] [/URL][/IMG] Picked up a Homelite LR4400 generator with a 8hp Briggs on it from CL, has a tapered shaft and no key way cut out. What's the best way for me to use this motor on a mini bike????
  8. Jamie1972
    8hp Tecumseh carb.
    Looking for the carburater bowl fuel adjusting needle, spring. (On the bottom) I cannot locate mine and I need one. Any help or leads are appreciated. If someone has a complete carb. That's junk other wise let me know too. Thanks.!
  9. 125ccCrazy
    Briggs 8hp I/C
    Good running engine, low hours.. $100 o.b.o Will ship added fee
  10. Sixpac440
    Can I add a starter motor to am 8hp Tecumseh?
    Did a search, nothing ... I have a mid 70's Heald VT-8 that I would like to add a starter to. It has the hump in the shroud ... Is the motor an H80? Do I need to tap the block? What starter? A snow blower starter with the starter button attached would be OK. Suggestions...
  11. ludicrous speed
    honda 8hp motor low run time
    honda 8hp low run time. 1 inch shaft,ran great,is nearly brand new. was bought brand new by friend who never used it,engine sat for long time bottom of recoil shroud has rust. will post pic. i bought it off him,went thru the entire motor/carb,had it running perfectly and then traded it to...
  12. Sixpac440
    NICE Super Bronc 8HP - $700
    https://nmi.craigslist.org/snw/5685529788.html
  13. CLH
    Wanted Briggs & Stratton 8hp flathead
    I am looking for a flathead 8hp Briggs motor. 8hp with 1 inch shaft. Shaft must be at least 2 3/4 inches long. Or provide me a model number and type to see if I can find a shaft to swap in. Cases should be smooth without studs sticking out, most I/C series engines will NOT fit in this...
  14. T
    Briggs 8hp. Shortbock
    New, disassembled Briggs 8hp. I/C Dual bearing cast iron bore shortblock. 3/4 inch pto crankshaft. $85.00 shipped to lower 48. Thanks
  15. Peekster
    Looking for pics of a Alsport with a 8hp tecumseh
    Looking for a pic of a alsport with a 8hp tecumseh. I need a pic of the gas tank used. Thanks
  16. Radford46
    Tec 8hp question
    I found this 8hp Tecumseh on a Coleman generator. Will it work fairly easily if I want to put it on a Super Bronc?
  17. P
    Any info on this 8hp B&S?
    So my friend gave me this motor, and aside from being an 8hp Briggs and Stratton with a 1" output shaft I don't know anything about it. Will this be a good motor for a mini bike project? I plan on running the gear directly on the output shaft and the centrifugal clutch on the jackshaft. Also...
  18. D
    Briggs & Stratton 8HP Buggy
    This is a fall/winter project me and my brother made. Its a fully homemade frame with front shocks of a Kawasaki 250 i think, rear shocks from Beverly 250, front wheels of a Suzuki Alto 1.0 (Suzuki also donated an alternator). Engine is a Briggs 8HP flathead with a carburetor from a 12.5HP flat...
  19. lostinbaja
    8HP Briggs head gasket?
    I have an old (1971) 8HP Briggs that blew a head gasket. I machined the head, installed a new gasket, torqued the bolts. Now that the engine has run and cooled, should I retorque the head bolts?
  20. MarksA-C
    Two Tecumseh 8hp Engines with lighting/charging coils
    Both of these engines have the lighting/charging coil. The black one is newer and runs with great compression but the carburetor needs servicing. Electric starter works and the plastic tank is solid and does not leak. 1" wide and 3" long shaft. Still set up as a snowblower engine so it...
