Hi all,
I'm retrofitting a piece of equipment to my utility engine for my mini bike and I've noticed that I have three different types of crankshafts on my three engines. The part I'm concerned with is the increased diameter step up that occurs on the crankshaft right before the 4 bolt mating surface on the engine. I want to slide a piece that has a shaft that rides on the crank and then has a plate that bolts up to the motor. The problem is, the crankshaft has a slight step up at the very end of the crankshaft near the motor. This doesn't allow the shaft to slide on all the way (because the step-up stops it), and the plate doens't make full contact with the bolt pattern flange and leaves a gap. I was wondering if you guys could take a look at your motors and see what type of step up is typical here and how long that distance is. My predator motor has only a 1/16" long step up, my honda has no step up, and my briggs has a 1/8" long step up which leaves a large gap. Any input would be greatly appreciated.
Thanks,
M
Thanks,
M
