What is the best way to set valve lash on a Briggs 5hp? Like what is the best way to take material out to open the valve lash? File? Sand paper?
I have seen the block of steel with the hole in it and the you lightly sand material away to achieve the proper clearance but I do not have one. Which is better to to remove material from, the lifter or the valve? :shrug:
