i always take it off the valve stem but i dunno whats beter. I do know wider is better :thumbsup: If its power on the cheap your after you can go real wide. I dont even use a feeler guage. just twist the valve with your fingers and youll see at what point in the stroke it actually closes. you can take it down till the valves are actually closed most of the compression stroke. But leave atleast 1/4 stroke overlap. only downsides are hard to pull rope and slighly more valve noise. try it on a junk engine first to see if you like it. You will like it :laugh:
