Vibration issues solved but lost compression!
trinik7597
You don't need any sealer on the head gasket... a new thin metal gasket is all you need .. and you can't read a plug accurately if it has idle time on it .. you need to put in a new or clean plug . Run the motor at higher rpm for a few minutes kill it with no idle time then pull it and read it
