Vintage Snowblower
As I was contemplating purchasing this, someone else snatched it up.
My question for when the next time one of these becomes available, does this Briggs and Stratton/snowblower setup always have a 3/4” keyed crankshaft PTO?
And if it does, is the PTO end threaded for a retaining bolt?
I’m also assuming that it is not a big deal to swap the cam and side cover to eliminate the reverse shaft, correct?
It was a bit scary, but I was able to successfully drill and tap the crank of my current engine.
So is it also safe to assume that "most" rototillers with a Briggs and Stratton from this era are also 3/4" keyed, drilled & taped?
I had a big disappointment when I removed the water pump from this 1980 Briggs and found that the crank was 5/8" and threaded.
Oh well, lots of other usable parts on this engine. And I only paid $20.
Just about every tiller I have seen you can see what size the pulleys are and if the end of the crank is tapped. I bought 30(I know too many) engines this last spring and summer,both tecumseh and briggs, and all but 2 were 3/4 inch and threaded.
That is useable. Just need to cut a keyway easy
I just use a thin cutoff wheel small diameter and cut the two edges and clear out the middle. finish off close to the engine with a smaller dremel wheel. It doesnt have to be perfect. But my results always turn out pretty close.
Even though timing is not an issue, is the PTO keyway typically at a specific crank angle in relation to TDC?
