Wanted: Clinton Tillotson Carb Diaphragm
cl350rr
Looking for just the diaphragm for a Tillotson HN series carburetor. Commonly used on Clinton chainsaws and post hole diggers, it is a single diaphragm carb with 5 mounting screws around the cover. I would also be interested in the original Clinton part number.
Looks like the one in the picture just made out of rubber instead of rock.
May be interested in more than on if the price is right.
thanks
Randy
cl350rr
Hl diaphragms have 6 screw holes I think and would be larger in diameter, If you have a carb handy could you measure the diameter?
cl350rr
Not a problem, thanks for offering. HN diaphragms seem to be very hard to find. I think the carbs were only used on Clinton engines. I found a source for some HL diaphragms so I am going to give a try at modifying them, current oriental manufacture not nos.
cl350rr
Yeah, I contacted him and asked if he would sell diaphragms without the kit as I would buy many if he did. The answer I got was I needed to contact Discount Marine, I assume that is where he gets the kits from. If I can make any of the readily available parts work I will go with them.
