I need a set of neck bearings for a Baja MB165 Heat/Warrior. Also need a clutch cover.
Belbuekus Member Oct 24, 2015 #1 Oct 24, 2015 #1 I need a set of neck bearings for a Baja MB165 Heat/Warrior. Also need a clutch cover. Last edited: Oct 24, 2015
deejaaa New Member Oct 26, 2015 #2 Oct 26, 2015 #2 take the old ones to a bike shop and they can match them up close enough. get the metal cage instead of plastic that came with it.
H Hent . Oct 26, 2015 #3 Oct 26, 2015 #3 https://www.OldMiniBikes.com/?target=product&product_id=8769
Belbuekus Member Oct 29, 2015 #4 Oct 29, 2015 #4 Thanks for that idea deejaaa. Last edited: Oct 29, 2015
Belbuekus Member Oct 29, 2015 #5 Oct 29, 2015 #5 https://www.OldMiniBikes.com/?target...roduct_id=8769 Golly Hent, I checked OldMiniBikes but couldn't find them listed. Now, is the bearing set up for the MB165 the same as the MB200?
IJG New Member Nov 3, 2015 #6 Nov 3, 2015 #6 Golly Hent, I checked OldMiniBikes but couldn't find them listed. Now, is the bearing set up for the MB165 the same as the MB200? well?
