If you have the original sprocket, you can drill using the old one as a pattern--just make sure you center it well. I have been using 1" spacers (use threaded rod connectors) to properly set off of the Bosch wheels. Then, use a step drill and drill the sprocket center out to 1 3/8" (snug) and use a 5/8" ID flange bearing on the sprocket. This saves the wheel bolts from twisting and snapping the rim under high torque.
