Its "new to me". I bought it last week off Craigslist and it doesn't run yet. I work a lot so I have not had any time to really look it over yet. Im going to try to do a little work on it this weekend, hoping it just needs a new carb and throttle cable but who knows til I get into it.
This is probably obvious and you most likely already planned on doing this but......Since the bike is new to you and there's no way of knowing how the previous owner cared for it, I would change the oil before running it, most especially if that oil fill hole is indeed open and is missing the dipstick. There's no way of knowing what may have contaminated the oil or what condition it's in.
As far as replacing your carb is concerned, if it's fouled up, you might consider running some Sea Foam through with a fresh tank of gas to clean things up. I swear by this product and it has worked like magic for me in the past. If that fails and you still feel the need to replace the carb, you might consider disassembling and cleaning the one you have now with carb cleaner. Rebuild kits are available which come with diaphragm, gaskets, jet, etc. The kits are usually pretty cheap. Compare the cost to that of a new carb and see which is the more economical way to go. Some folks probably would prefer just to install a new carb and not have to deal with the hassle. Personally, I like to tinker with such projects, so I tend to prefer that route.
