i see you mention about my discovery on using animal springs and dyno retainers from a briggs flathead and modifying them to work with the single springs(animal) and using the newer compression release cams in your pinrepair right up and me not getting any credit for it....lol. there is one more retainer that might work and that would be the tecumseh motorsports parts. maybe on my next small block build i will look into this and if it works you can add it to you pin right up.
also in your right up i feel your little misleading on the 245 cam and it's power band(rpm range) you say it's only is good to 5000 rpm's?
i guarantee with my 245 in my hs-40 it pulls easy 7000 rpm's. if i am correct that cam was rated for 6500+ in a ohh-motor and 255 was 7000 and the 356 was 9500. here is also something you cam mention in your right up. dyno will grind other profiles. i know of one other member here pm and told me they had a 308 profile ground. just may try that out in a ohh motor some day.
running a 18 pound springs is not alot of spring pressure for a stock or even a 245 cam. when you start to get into the 20+ pounds and above you can start to wear on the cam if it's not harden correct. i just tore apart my hs-40 a while ago and did not see any damage at all on the cam lobes and that was using 18 pounds animal springs and we all know that engine went to hell and back more then once...lol..
also looking back when you installed the newer compression release cam in a old hs block with the hs lifters you where getting about .030 higher lift. thats because the newer cams with the release have a different base circle then the older cams did and you where picking up the extra .030+/- height. not the reason why tecumseh was getting 5.5 horse power out of there engines. 5.5hp is more then likely coming from jetting,rpm settings...etc.....
if your going to have this info out there for everybody to see need to try to get some of this more accurate....
