Hi, new member here. I picked up a mini bike off CL a couple weeks ago that was just listed as a "baja mini bike". No plastic can, repainted with a rattle can, and needing some reassembly. I've concluded it's a baja warrior (MB165?), with a 196cc stock motor. I have most everything put back in the right place, but for the life of me I can't figure out where two of the four springs go. I got the throttle limiter screw and spring back in place, and what I believe is the governor spring on the linkage, but the slightly heavier gauge spring shaped like the governor one, and a much bigger spring shaped like a trampoline spring are lost on me. Currently the bike fires up in one to two pulls, but the throttle doesn't give it gas, so I know I'm close.
Basically signed up here in hopes someone could share a clean picture of a stock assembly for me. Can't find anything online, and the part list baja has is very low res and possibly wrong, if me buying a M12x1.25x25 bolt for the clutch is any indication of either of these issues. Also, sorry if there's a post for this very issue. I tried using the search function but nothing popped up for "throttle assembly", and I'd like to get this running this weekend.
