throttle assembly
  1. Z
    80CC Predator Throttle issues and general transmission issues
    Hello, another question about my Blazer 2 Speed. With a GoPowerSports 80cc throttle assembly kit, it itself works, all parts, with a returning throttle. however, the governor assembly does not activate the throttle. In the reddit comments of my video here, , they say that if it was on it would...
  2. M
    2 Coleman mini bikes with throttle problems
    Hello all, I am new here. I acquired 2 Coleman mini bikes that the throttle hangs wide open on. I don’t have much info on them, all the guy said was that the throttles hand up. Got ‘em home and fired them up, sure enough they both hang up. Took the tanks off and started investigating, He had...
  3. Jblack0884
    Coleman CT200U won't rev when throttle
    I have a Coleman CT200U it was fubar when I got it I've changed the throttle assembly and so on and so forth but what my problem is is when I try to rev it doesn't not rev up on the throttle and it won't take off I've also changed the centrifugal clutch because it took off by itself prior but...
  4. M
    sprocket size help
    So I bought a 2002 murray track 2 for $150, the throttle has a connecting wire missing, there is no brake at all, chain is loose, starts to die a couple seconds after starting. I am working on fixing all that, and will be swapping engine with a 212cc preador in a couple months. My question is...
  5. W
    Baja Warrior(?) 196cc Stock Throttle Assembly Setup
    Hi, new member here. I picked up a mini bike off CL a couple weeks ago that was just listed as a "baja mini bike". No plastic can, repainted with a rattle can, and needing some reassembly. I've concluded it's a baja warrior (MB165?), with a 196cc stock motor. I have most everything put back in...
  6. 09thirteen96
    Throttle lever & Vent filter ?
    I have 2 quick questions. First, is my predator engine gonna be fine without the linkage lever? By fine I mean is it going to stop me from making future mods? I took my bike to a shop for help connecting the throttle and when I got it back the lever was no longer there but the throttle is...
  7. 09thirteen96
    Throttle lever & Vent filter?
  8. Throttle Assembly
    Throttle Assembly
    Predator 212 Throttle Assembly top pate
