Hey All, Just picked up this Baja Minibike with literally no stickers or anything saying the model or engine size. From the research I did only using the serial number I have a hunch that it is a 2005 MB165 / HT65. I really don’t know much about these bikes but does that sound right? If anyone has any input about what they think it is that’s greatly appreciated. I have predator swapped a manco streaker and a wildcat before but they were death traps. I would like to do the same preadator 212 swap with this Baja. I’m new to the jackshaft tech though.
Another question: Would the swap be hard to do for this Baja? Would I have to eliminate the jackshaft or could I use it? I would like anything possible to keep the chain from popping off ( previous problem that kept happening to the streaker and wildcat.
would I need any adapter plates or anything else to make the predator swap work? Also would the stock Baja clutch work on the predator shaft? I could get a new clutch but uncertain about the chain size and shaft size. Any other information would be greatly appreciated.
I went over the bike and do not see any cracks in the frame or engine plate. Thank you!
