"Richard J. Smith custom built mini-bike for Bob Noble. Butane fired with an Ohlson and Rice model airplane engine modified for a bump valve. Typical Smith mono-tube steam generator with automatic controls, water pump, and an oil cooler modified for the condenser. This is a typical Dick Smith design using a helical coil steam generator and a control system based on his patent #3,507,258 that uses several bell cranks for an analogue control with inputs from steam pressure and steam pressure and outputs to the water pump feed rate and fuel control. Everything that is needed for a steam power plant is present in this mini-bike. At the present time the O and R engine is worn out and needs rebuilding."
I picked up this frame years ago. It looks like some kind of lay down thing. Frame is extended with footpegs in the rear. I've been thinking about putting a snowmobile engine on it. It would be wicked!
Tom
Tom
Lol, I don't know what it is. Why is it a lay down style? Land speed record attempt??? Actually, the workmanship isn't too bad, but it is a puzzler.
Tom
