Check out the links below to see the clutch in action. We've come to the realization that we definitely need more horsepower to really put the prototype through its paces, and we'll make that our next project. That being said, the clutch handles this stock predator with ease. In the video you'll see that we're using a lever to actuate the clutch, but the production clutch will be operated via cable.
Custom Manual Clutch Go Kart Burn-out Predator 212 - YouTube
Custom Manual Clutch Predator 212 Kart - YouTube
Also, we did some primitive torque testing to determine the maximum torque capacity before slippage of the clutch. We used a breaker bar on the crank and locked up the sprocket using an extra piece of chain clamped to our weld table. We then hung weights off the end of the breaker bar and determined the max capacity to be 42 ft-lbs. In the future, we will offer springs with different load ratings so that users can select a spring setting based on their specific setup.
