11hp
  1. Z
    Baja Warrior with 11hp Honda
    Soooo I've picked up a Baja Warrior with this 11hp Honda on it. It has no chain, clutch, TQ or anything. I'm trying to figure out the best way to get it moving. I see that there are some TAV2's on Ebay that claim to be able to handle up to 11hp, but idk about that. That's one option. Another...
  2. bikebudy
    340 Clone 11HP Question?
    Got this 340 / 11HP Clone the other day. It has Elec / Start and lighting If you try to start it will not but, if you add the light coil to the Ing coil , it fires up ? Remove the light coil from the Ing while running, it stays running but, if you shut it off same thing. Also, there...
  3. Roadmaster75
    New Tecumseh 11HP OHV for the MW Trike
    Looking for any comments or experience re-carbing with this motor. I have been working on a MW Trike on another post: http://www.oldminibikes.com/forum/vintage-trikes/119588-montgomery-wards-zcq-13995b-cestad.html But, I thought I'd post a couple of pics of what's going in the trike...
  4. J
    11hp briggs and stratton mods
    This engine is a syncro driving a power washer. Its set up to run at 3600rpm. How do I get it to idle and how do I set you a cable operated throttle?
  5. cyruss503
    Honda gx340 11hp
    Hey gang! ltns! been busy and havent been by much lately! anyway im selling my Honda gx340.. Its a BEAST of a motor and has a 1" keyed shaft.She starts on 2nd or 3rd pull everytime.I realize it has a 390 recoil cover on it but that was a fix on my part...It has a predator tank on it but i will...
  6. omb_026
    omb_026
  7. omb_025
    omb_025
  8. omb_024
    omb_024
  9. omb_023
    omb_023
  10. boostdoctor
    What's the difference between 9hp & 11hp gx340?
    I just picked up a 340 and it says 9hp. I assume this is a older model motor. What extra does the 11 hp motor have?
  11. jeep4me
    11hp Tecumseh
    I pulled this 11hp Tecumseh off from a big John Deere snowblower. The blower was toast but the engine is still usuable. It has electric start, working lighting coil and runs good. I will also include the light that originally came on the snowblower. The tins and housing are very rusty, but could...
  12. scootercat
    Murry lawn tractor w/B.S. 11HP
    Hey Gang, Its getting that time of the year when thoughts go to thrashing the grass so I've got this Murry tractor, last year I was cutting the back lot,beer in hand,mp3 player blasting in My head and cutting good,this thing just stopped running....At first I thought ,gas?...Nope just topped it...
  13. FirePowerMinis
    11hp 391-392cc? Mitsubishi/Briggs
    Any one modding these? I ended up with one, and it runs. Looks a lot like a GX390. Nicer rockers, I think.
  14. cat123456789101
    11hp chopper project
    Hey guys i just wanted to hear what you all think of me making a doodle bug chopper with an 11 horse honda gx340. i am wanting to extend and raise the bike to make good room for the big beast and for the bike not to flip over! LOL
  15. Heald Super Tryke 11hp
    Here's our Carl Heald Super Tryke, just bought it yesterday. It already runs & rides great & I'm starting a cosmetic resto on it now. This one is their mid-size trike, 11hp Briggs with electric start, no reverse on this model.
  16. Heald Super Tryke 11hp
  17. Heald Super Tryke 11hp
  18. D
    Honda GX340 11HP motor question
    I picked up this motor today. It is mounted on some sort of water pump. the brand of the pump is Sprak. Does anybody know if the motor has a straight or tapered shaft? What size is the shaft? I believe it is 1".
  19. Kustomtoyz
    Tecumseh HELP 11hp carb starving for fuel
    Just about done with the build and now I'm having problems with the stock carb. This is a brand new (old stock) motor. Ran fine about a month ago but now it only idles. Any throttle with the choke off, it trys to die. Choke on, rev's up... I've never worked on this (new) type carb with the...
  20. Beal
    11hp flatty, simple things?
    So I have a 11hp e-start Briggs flatty. Its going into a baja heat minibike. Obviously, the frame will be modified to accommodate for it... But, seems I have some questions... For the frame, What thickness of steel plate will be got for the motor mount? For the motor, What are some...
