Hey all!
I hope you all are great.
I have a question, i got two 212cc minibike, both of them suddenly has gotten wobbing backwheels.
I cant understand why or how this could have happened since i havent used them so much.
All I can think of that I did diffrently is i tried to tension the...
Hey all, newbie here. never been into minibikes and engines much, but i saw a baja doodlebug at a garage sale and it was too good to pass up. i bought a 212cc predator engine from harbour freight and am planning to put it in. any advice, extra things i need to buy, etc? advice would be much...
I have a 212cc non hemi and I want to know how much hp im making. And once I know how much hp im making I need suggestions on 1/8 gear ratio (clutch to sprocket)
Currently have 12t clutch 70t sprocket
Dyno cams - mod2
18lbs springs (26lbs on the way)
E tube and .32 jet
2 degree timing key...
Bought 1.3 rockers and didnt get plate for it cuz affordablegokarts said you could modify stock plate....... what is the mod I have to do?..... Cut out the slots where rods go? Idk
ok so I have a 212cc predator with a jet kit from OldMiniBikes warehouse and an air filter from studz.... and it is running terrible for some reason! the only thing I did was change those 2 things. When I go full throttle it feels like something is holding it back... like not enough air or something. Can...
Hi, have a 212cc Predator on my Trisport TS-110
Riding it today i tipped it and the cover for the air filter broke off
i cannot find a stock one and wish i could, i seen an 'aftermarket' one on ebay but am cautious about buying it.
anyone have an aftermarket one and could comment on it...
Cat 300x Minibike
This is my Cat300x, i bought the frame and wheels for $20!! It was an amazing deal, anyways here is a video of me doing a walkaround. :)
6.5Hp Minibike - YouTube
So I got the motor from a friend and it ran but it had been sitting for a while in the rain and shit so it needed to be cleaned up.. I cleaned the carb, than I removed the governor and put a screw in the top of the block.. Next I began to get a throttle linkage going.. Put in a new return...
I am currently in the process of my first mini bike build. I found a frame (i think it's a bird wren) in the area for $75 and HF was having a sale on predators so i went and got the 212cc. It's been about a month and so far the motor's been disassembled and waiting to get beefed up with a stud...
ive done a couple of mini bike projects and am working on a third. check it out and let me know what you guys think and maybe a couple of suggestions.6.5 Monster Minibike - YouTube
