So I have 2 coils, each is 3 Amps with a single wire on each. I believe this means it's a half wave and one end of the winding is grounded to the coil itself which is then mounted and chassis grounded.
I want to run 2 full wave 12v scooter/gy6 4 prong rectifier/regulators. One to charge the...
Do any of you guys play? And if so have you ever made you're own amp? I've had this idea ive been kicking around my head for amps and I have some questions.
Here's my axes and amp
New 2007 Honda GX160T1 QXS2 with Lighting Coil- Standard 3/4" crank keyed I believe 2 7/16" long 5/16"nf tapped.
Engine was just removed from box to take these pictures. I have had it since 2007. The tag says it is a 50 AMP coil but pretty certain it is a 50 WATT charging coil. At 50 amp this...
Here is what I am starting with on this project. The seat is missing along with most of the variable pulley setup. The engine is locked up and missing most everything except the bare block.
