Just swaped out my old 3horse Tecumseh for a 6horse predator. Chain keeps coming off when under stress of acceleration and also when just cruising. Tried pulling all slack out but is still happening. Broke 2 master links, I finally just welded chain and made master link unnecessary. Chain still...
i would like to have a used 1' clutch form my go kart. preferable be able to go all the way onto the shaft. needs to be able to handle 11ph too. looking to spend max is $100.
I NEED A CLUTCH ASAP SO I CAN HAVE IT DONE BY SPRING!!!!
I swapped my 6.5hp HF motor on my doodlebug I made sure the chain wasn't too loose. I got the clutch inline with the rear sprocket as close as I could eyeball it and verified with a straight edge. Everything looks good but it still throws the chain very easy. I barely make it out of the...
