Hi!
I am on my 4th and 5th Rebuild I was lucky in my first 2 rebuilds I did not need to replace (just the inside seals) . I am in dire need of the the hard rubber dust covers that slips on the lower shock absorbers.
Anyone know where I can get these? I have ordered 3 sets online...
Hi all, I was talking to Mr.Kimball yesterday about the super broncs and parts for them. I asked him if he knew of any shock boot out there that would work for these and he said " a matter of fact I had another gentlemen a few weeks ago looking for these as well, he called me back about a week...
I had to pull down My benelli Hurricane off the shelf so I can swap the shocks off it. its been up there for a few years now along with my Z50. You would think they were up there for 100 years as nasty dusty/dirty they are :doah:
I do dust from time to time, but that the side I could...
For the K & N knock off filters we are using.... I was un sure if it was to be oiled (with k$n oil) or not.....
Well today I pulled it (never oiled) and found traces of fine dust around the pilot jet (idle) passages in the carb.....and on the adapter for the filter.....
So i shot a light...
I put the first coat of paint on my custom today after giving my garage a good cleaning. When I was finished I noticed little spec/bumps on the back fender. I guess this is dust that has settled on the mini while the paint was wet. Can I wet sand those marks out? Maybe with some 1000 grit?
Did Ruttman 4-spoke alloy wheels have an OEM dust cover over the bearings?
The hub area around the bearing registers is machined in such a way as to appear to be made for a cap or cover over the bearings...
Thanks for any info...I'm thinking about machining some billet bearing covers for...
