electronic ignition
  1. Orson_Yancey
    What years did Tecumseh place points under the flywheel but external coil outside above flywheel?
    Hi, In the 1960's and 1970's, Tecumseh used a magneto (points, condenser, and coil) located behind the flywheel. And I understand that it is difficult to change these engines over to electronic ignitions. By about the mid-1980's, Tecumseh changed over to electronic ignition, (CDI solid...
