weve been redoing some of the 8-10hp motors,w 1 inch shafts,
and we are having some serious problems trying to decipher which cranks to buy to Replace the cranks in the motors now.
first motor is a 8hp?? sears snowblower -1 inch shaft no Pto bolt hole.
143666032 unknown year maybe? 77
this...
I picked this one up from CL , needs a 48 volt motor controller as far as I can tell. None of the generics match up.. Any info on this thing would be gratefully appreciated .
:scooter:
Ok All you gear ratio specialists if I have a 12 tooth clutch going to two 15 tooth gears on a jackshaft back to a 59 tooh gear what is the ratio:shrug: the rear tire is a 130/50-8 if you need that too. looking for a high speed gear on a light bike.I can only change the jackshaft sprockets.Thank...
