primary
  1. Biodude
    WTB: 1968 Rupp TT500 Primary and/or Secondary(Jackshaft) Clutches
    Looking for original clutches for a restoration that I want to complete. Let me know what you have! Thanks in advance!
  2. M
    rupp black widow primary clutch parts
    Looking for Rupp primary clutch part # 15105 this would be the stationary half of the primary clutch on a Rupp black widow.
  3. N
    72 motoskeeter 550 primary clutch nylon bushing needed
    Help needed with finding the splined primary clutch nylon bushing for a 1972 motoskeeter 550 mini bike. Anyone know of a source to get this bushing or any ideas on how to make this plastic bushing??? Just picked this complete bike up and need this piece. Also can anyone tell me what the correct...
  4. Boomstick
    Primary differences between HM100/Stars?
    I recently picked up a very nice HM100 for free off of my neighbor who just wanted it out of the garage. It actually runs nicely, but could probably use a good carb cleaning. It's an iron bore, and gets great compression. Now if I remember correctly, the Star is a (albeit heavily) modified...
  5. Clayon
    Primary Clutch Removal Trick
    Just thought I'd share the trick I used to remove the stationary half of the primary clutch on my 2-cylinder Kohler 2-stroke. The stationary half of the primary is often stuck on the tapered end of the crankshaft and a clutch knock off tool is needed to remove it without damaging it. You...
  6. Jamie1972
    Rupp TC-1 Primary clutch complete
    Rupp TC-1 Primary drive complete unit in good working condition w/hardware. 60.00+10.00shp. Thanks!
  7. Jamie1972
    WTB: hs40 Primary drive disc's
    Looking for the inner aluminum disc that go's against the engine. If there is a matching outer disc also available I would consider that too! Thanks!
  8. E
    Comet 20 primary clutch
    I have a comet 20 sieries clutch that has been on a shelf for a long time and is stuck. Any pointers on taking it apart? There are 3 allen screws holding the rear sheave on. If I remove them and get that sheave off will it come apart?
  9. W
    CCW primary coil
    I'm looking for a primary ignition coil for a CCW/Kioritz KEC290. The entire coil plate assembly or a CDI conversion would be even better.
  10. grindking
    need primary clutch & cover 72 artic cat
    not sure what yr but i need clutch cover & a primary clutch also a nice gas cap if there is any out there? thanks pm me if you have or know any1 how has this
  11. gpxsrxracer
    Rupp Primary clutch TC-1 wanted
    Looking for a complete TC-1 Rupp primary clutch for my 71 Roadster. Also a nice secondary clutch as well. Primary clutch I need for sure! :thumbsup:
  12. 1 week old chain
    1 week old chain
    Primary chain ruined after 1 week
