unit
  1. smudvapor
    71 Rupp Driven Unit
    Is there any special way one of these goes together? I can't find anything on the web. When we pulled the TC and the driven off the bike it all worked. Now I can't get it to work. I have checked the TC a bunch of times so I am thinking we did something wrong with the driven unit.
  2. C
    GTC/Comet Driver Unit
    GTC 1005 3/4 driver unit. Compatible with Comet TAV2, Series 30 torque converters. New/unused, less shaft bolt/washer. $45 shipped CONUS.
  3. M
    Wanted original comet series 30 1" bore driver and 6" series 30 3/4" bore driven unit
    Looking for NOS Comet Series 30 1" bore driver for engine PTO shaft that uses the asymmetric drive belt and the matching Comet Series 30 3/4" bore 6" driven variable pitch pulley unit. Must be made 10+ years ago by the original Comet Industries. I realize the newly taken over Comet...
  4. David wulf
    Needing a TAV driven unit
    I'am in need of a TAV driven that fits a 3/4 shaft . Can be 6" or 7" . Have cash to buy tell me what ya got .
  5. S
    Engine display unit
    I figure this is the best place to post as it is briggs and has to do with engines. I found this a few years back and have not seen another one, any info would be great. Thanks Scott. Sorry about sideways pics
  6. 2SlickNick
    Old Comet Driven unit Stuck
    I have this old comet 20 series driven unit that is 40 years old and I can not get the cam off..... I removed the 3 allen screws ( which should be like a retaining clip on new drivens ). Not sure if it is stuck from 40 years of corrosion or it was never meant to come off. What do you guys...
  7. MB165
    wanted 7" comet 30 series driven unit
    im looking for a 7 inch comet 30 series driven unit. part numbers are 217611A or 217778A. any condition.
  8. wildman
    2 Sperry Rand Tricubs - restoration project thread
    I have started working on the 2 Tricubs that I acquired last year. These were both originally 8hp/elec start units (model 38E), which seem to be considerably scarcer than the 5hp version. The first unit (unit A for this thread) is pretty nice, unmolested body and frame, but no engine. I have a...
  9. M
    Broken spring on Rupp driven unit
    Any help with finding a replacement spring for a rupp driven unit would be greatly appreciated. thanks, Mike PS: posting pics of my latest build
  10. catfishman
    need an new ac unit
    okay, so my ac unit went out the other day. we have the home protection plan, which is not all its cracked up to be, from what i have heard. anyway the company that they use sent out a guy yesterday, and met with my wife, i had to work. the good thing, he said we will need a new unit, the old...
  11. D
    Help with this unit
    Good day fellas any idea what if any mfg this one may be?
  12. KustomKartKid
    Complete V-PLEX TAV Unit For MTD and Others
    ****SOLD*****:hammer: After searching forvever I bought a whole 'nother bike to get this original V-Plex TAV assembly for my MTD, and boy was it worth it. Turned it into a whole different bike. Lots of top end speed and enough bottom end torque to pull the front wheel off the ground and...
  13. oil_switch
    oil_switch
    oil switch ess unit
  14. R
    rear brake unit for lil indian sabre
    looking for a comlete rear disc brake unit for my 1970 69? sabre:bowdown:
  15. H
    Engine Control Unit (ECU) using dsPIC33F
    Hello guys, I made a Universal Engine Control Unit (ECU) using dsPIC33F equipped with DSP Engine, it can run any Gasoline 1,2,3,4,6,8 Cylinder Engine. it can also support VTEC/VVT, + lot more advance features Have a look at it Engine Control Unit using dsPIC33F - YouTube Best...
  16. KustomKartKid
    Complete TAV Unit For 1970 RUPP Roadster
    Here's a complete RUPP TAV setup just as it was pulled from a running '70 RUPP Roadster. All the original parts and pieces are there incuding the sleeves, spring, spacers, washers, retaining bolt.....even the little keys. Slight wear on the bottom of driver sheaves ...the driven pulley and...
  17. H
    Engine Control Unit ECU for EFI Engine (home made)
    Hello Guys, this is my first post over here, i wanna share my work with u guys, i dont know is that the right forum or not, here it goes some thing like this i made my own Engine Control Unit ECU using PIC Microcontroller have a look at it Engine Control Unit ECU using microcontroller...
  18. O
    TC 88 torque converter Driven unit
    I'm looking for a 5/8" shaft, with a 5/8" belt driven unit. Is there one still out there to be had?
  19. pomfish
    Need Baja Gear Reduction unit
    Looking for a good functioning inexpensive Gear Reduction/Jackshaft from a Baja or Warrior. Must be #41/420 chain type. If someone has a takeoff after having upgraded to a TAV that would be great. Thanks, Keith
  20. S
    Help installing a torque converter drive unit
    I have some questions about my Comet torque converter. I want to make sure I install it on my motor correct. It came on a 285 Manco Dingo back in 1986ish. When I received the kart, the driven part is still attached. I do see it has 3 buttons and one is missing. Other than that, I think I have...
