I'm listing in this section due to listing as a complete or roller. Chrome on fenders is nonexistent but the rest of the bike is decent. Tank is good and has no leaks, I cleaned inside and sealed with red kote just to give it a fresh interior. Bike has dura DOT street tires that are in good shape. Front and rear brakes work, although front is not hooked up. Motor is a GX160 14cc head milled .030 27/25 ss valves 26# springs arc rod black mamba cam Honda flat top piston flush with the deck .010 head gasket 10 degrees timing rubber valve cover gasket 22mm mikuni carb uni air filter, may be missing something but you get the picture. Bike is pictured with a noram ge clutch but will be selling with a comet and header will be changed to rlv pictured with the factory exhaust which is what had till I recently tried a new pipe out. If you want it as a roller I have the factory exhaust pipe and the nipple the screws into the Tecumseh exhaust port. Roller $250 complete $600. Currently to busy to break down and ship so local pickup but I will work with your shipper.
