I have had a Go Devil sitting around for many years. It is missing the original plug. Appears that someone tried to substitute a plug that may or may not be correct type or heat range.
Does anyone know the proper plug for a 71 Go-Devil with a 50cc 2-Stroke motor running 20:1 gas
il mix?
Had a Champion CJ8. Have read something about a NGK B-6(Could not find in the NGK Cross Reference Charts....Partial maybe??)
Any tips on carb setup? Runs extremely rich on a Champion CJ8 plug used for quick testing. Won't idle without alot the idle screw full in. Carb is extremely clean. Needle doesn't leak. Float height adjustments?
Compression and spark are solid. Pulls well.
Thanks Guys!
RocketRanger
PS: The other project is a Rockford Chibi.
Thanks Guys!
RocketRanger
