2021 build off 1968 Taco 44
Mini Bike & Go-Kart Parts
#22
If you don't mind me asking about how much was it to have them chromed. Got some fenders that I would prefer chrome instead of powder coat.
I do all my polishing myself .Thats the expense in chrome and takes alot of time. to dip with nickel and chrome ,I pay min charge 100 cdn
#24
Thanks, that sounds reasonable enough, comparable to powder coat prices.
its the pre work that expensive cleaning rust removing paint removing the chrome sanding polishing removing every scratch and pit I spent a lot of time prepping some ware around 30 hours.Chrome does not hide anything ,the plater I use is industrial does thousands of parts a day ,table legs, chairs. racks.His building is about 60 thousand sf and about 60 employees and nothing goes down the drain,its green enviroment.If you take it to a plater make sure its clean and expect to pay for the time they spend prepping
#28
made up clutch cover mounts.Im not sure what the original look like made a couple of spacer and bent some flat bar .checked valve lash spot on ,head off crosshatch on cyl looks good,removed govenor found pieces in sump.plugged hole with 1/4 bolt I found that it will cut its own thead when installing.painted this morning will give it a week to harden and then put the tins on
