I have run a BM with 28.5/25 1.3 raceeng rockers with 26lb springs to 7500. ran great never had it higher. I also do not remember what my installed height or seat pressure was but I normally set them a bit tighter than the .850 installed height. A BMjr would require the 37 lb springs as its a more aggressive cam as far as lift per degree. For a new build I would go with 37lb springs just to be sure. There were a few people that had the red stripe 37 lb springs break and NR now sells a new one. I ordered it and got the green stripe duals and it is much stronger than 37LBS installed so I am guessing if I just check the outers it will be around 37. I have not had time to test it yet.
