301cc Predator 8hp - Put one on my doodle bug & engine info inside
So a lot of people know now of the harbor freight 8hp 301cc engine they put out - but there isn't much info out there on them. I Now have one on my doodle/baja bug - and hopefully I can help answer some questions. It uses the same gaskets/head as the honda 270 - and pretty much everything that the 270/390 has will work with it.
My mods: adjustable 390 carb - stock one isn't adjustable
exhaust
Milled the head .052 and got the thinner head gasket
Lighter flywheel
running a 420 chain
Torque Converter
hydraulic Brake
Nitrous Kit
Put a rear tire on it tonight - damn thing is a wheelie machine!
20151226_133328.jpg 20151226_133343.jpg 20151226_133411.jpg 20151226_140643.jpg 20151230_211516.jpg
Great info. I must have started my thread when you posted yours. This is one of my engine considerations for my project I will be starting.
FYI - I spoke to someone at nr racing yesterday & he mentioned most of the 240 & 270 parts will interchange with the 301. This will be interesting to see where the market goes on this one (or if it does).
PS nice green ride !
Good to know, I am leaning more towards the engine you have.
Did you have to grind the head a bit to get the torque converter to fit ?
What flywheel did you use (if you don't mind) ?
When I do teh build, I plan on adding an air filter, and making a custom pipe to go out the back under the seat (I have to see if there is anything I have to do the carb so I don't do something stupid like lean it out & burn it down), but letting any engine breathe a bit better can't hurt.
Thanks for the feedback.
I had to grind and cut the TC back plate. I put the adjustable gx390 carb on it and tuned it.
I used the forged flywheel that bolts the the gx series of engines, and did 6 degrees added timing.
X"N
New Member
Got any pictures on what you did to the TC back plate to fit?
Looks like you used a mb200 / ct200u 50t rear sprocket..I've thought about drilling one to use on a db30 6" wheel b 4..so looks like i could if wanted ..using a 420 10t clutch yielding 5 to 1 ratio..i just like 420 chain..i know the resistance more..but 420 hardly ever comes off...hmm..that thing a beast..nice job. :thumbsup:
