5hp Carb options
I was looking into switching the carb on my 5hp flathead, but in order to do that, I have to get a carb thats not connected to the tank. Is there a cheap option that will let me convert this? The engine in question is model 135202. Seems to be a pretty common engine.
I got that 16mm carb off eBay and I got my first welding lesson while making the intake manifold.
Not sure why it’s sideways but it’s here nonetheless
delray
16mm carb could be just little to small for that 5hp big block. I would go with a 22mm carb like this. you can find them on ebay and they use mikuni jets and pilots and easy to tune. also has a choke setup that works pretty slick once your engine is dial in correct. should take only one pull and starts all the time.
I still run a cheap 19mm on my briggs bike I built and it's a real pooch,need to up grade someday...lol also that carb only has a choke lever and no high idle when cold running it. 22mm mikuni/clone carb runs like a car choke with high idle until you want to take it off. I have notes some of the small cheaper carb's don't have this feature.(like my briggs bike)
Oh damn. I just went off that link posted earlier and I bought the 16mm. I guess I’m gonna try it first before I buy another carb
