Hey guys, first thread, but i got a major problem. just received my gx390 kit from NR with mikuni fuel pump and this thing won't idle AT ALL..
here is my Set-up
GX200 Clone:
-Aluminum flywheel
-ARC billet rod
-18lb valve springs
-Governor removed
-GX390 carb kit (carb adapter with pulse fitting, stock jet)
-straight header w/ RLV silencer
-Mikuni fuel pump
So i got a brand new gx390 carb and adapter and basically my problem is that my engine will start but not idle, if i keep opening the throttle it will stay on and run (i ran it for 15mins while repeatedly opening and closing throttle) when i start up the engine some white smoke comes out and if I give it some gas a large puff of stinky white smoke usually comes out. I tried adjusting the air mixture screw from half turns until the thing almost fell out, and i tried adjusting the big plastic idle screw. I also played around with the choke too. I am still pretty new to this stuff.
Heres a video YouTube - Mini Bike Problem (it runs like this no matter what i adjust)
here is my Set-up
GX200 Clone:
-Aluminum flywheel
-ARC billet rod
-18lb valve springs
-Governor removed
-Mikuni fuel pump
