Needing help with the front springs / shocks on my '67 Continental. Mine are currently stuck in the fork. One strut came out with the lower plug and about 2 3/4" of spring. So I suspect it is broken up inside, with part of the spring and upper plug attached. The other side has the entire lower plug, spring, and upper plug stuck in the fork. I am using a lot of PB Blaster to try to get this all out without much luck thus far.
Can anyone tell me the overall length of the front springs?
How do the springs attach to the upper and lower plugs?
Once you are ready to re-assemble them is there a lubrication process to use?
Any help or tips would be greatly appreciated.
Thanks, Mike
Wichita, KS.
Thanks, Mike
Wichita, KS.
