I'm currently running a mikuni, and just picked up a pair of mikuni carbs and the expansion chambers. The more I read about expansion chambers, the more I think the factory alsport ones aren't going to give me the increase in power I thought they would. I'm debating fabing a dual carb intake for the ax engines I have, but might be a wate of time and favors!
And I think I grasp the exhaust pressure building turbine speed on the turbo. But, my thought is if I introduce boost on the intake side, the added air flow would go right out the exhaust since there would be no valve to stop it. I too think 60 hp is what I need, and might be possible NA with the right exhaust and tune. As far as nos, I want to try it on a spare engine I have just to see what happens! The change in exhaust temperature due to the nos might actually be bad for the expansion chambers to work correctly, so it could be a fruitless endevure. Figure try the dual carbs, and expansion chambers, make some passes at the drag strip, and see what happens then go to the drawing board. If I don't hit 80mph in the 1/4mile, I will be very disappointed.
